跳转到主内容
加入维修社区 - 创建账户
第七代 Honda Accord,生产年份为 2003-2007 年。
02 sensor has no power on wire going in...
HI, my Honda accord 2003 2.4L i have a code po135, i no is the sensor bank 1-1, my problem is i don't get any power to the wire going to the sensor, i check the wire and seems to be oh. so any body have any suggestion what it could be? thanks.....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
vitodeluca, check these fuses first:
No. 19 OPTION (40 A) fuse in the under-hood fuse/relay box.
No. 4 A/F SENSOR (15 A) fuse in the under-dash fuse/relay box.
No. 23 IGP (7.5 A) fuse in the under-dash fuse/relay box.
Also, Oxygen Sensors need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element. It controls the heater element circuit by allowing current flow to ground.
So, your P0135, could be a bad sensor, but also a bad ECM etc. I would suggest that you replace the O2 sensor and then recheck to see if it clears the error.
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
Information on this is found here and also check this video for interpreting O2 sensor code.
这个答案有帮助吗?
得分 3
5条评论:
How can I locate Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse in Honda Accord 2004? Please need your help
完成的
My friend helps me to check, there is not enough power from the source, lower than 1V instead of 12V, he said might be the ECM issue. I hope not, ECM cost a lots to change.
Do you think it is a fuse issue? I have a small problem which cause my 7.5A fuse broken when connect my back up camera, my then the issue light up for O2 sensor.
Regards,
Andy
完成的
Would these fuses work for bank 1 sensor 2 as well?
完成的
check the relay, seems common issue if sensors are ok
完成的
Which relay should I check? I’m having same issue. No power going to o2 heater and no blown fuses.
完成的
添加一条评论
I also have a 2003 accord 2.4 with the same code. Inside fuse panel did not have a F4 laf fuse. The car sputters in idle. I replaced the o2 sensor and cleared the codes and still have the same code and spotter. My question is if there was no fuse in the F4 section laf heater fuse do I go ahead and put one in it's location? Also is it only on certain models that have this fuse?
这个答案有帮助吗?
得分 1
1条评论:
Are my 02 sensors faulty, I no reason at all it just says 0 0 0 0 0 on my scanner
完成的
添加一条评论
添加你的答案
vitodeluca 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 97
总计 72,272
