跳转到主内容
加入维修社区 - 创建账户
HP 530 笔记本电脑的所有型号。
no sing of life
hp dead, water damage, could not turn on,, what should i do, and schematics for it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
waspa, that's a mighty tall order. The very first thing that you should do is to stop trying to use your computer. Remove the battery. Download the service manual from here. remove your motherboard and clean it with 90%+ isopropyl alcohol and a soft brush. While you clean it, check for missing broken or charred looking components. Once it is all cleaned, reassemble your computer and replace the battery, then re-evaluate and see what you get. Any schematic will only help if you know how to read and follow it. You would also need to have the tools and the knowledge to perform board level repairs. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
how to make charger outer for battery for hb 530
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
waspa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 612
