跳转到主内容
加入维修社区 - 创建账户
本指南将介绍如何维修第七代 Honda Civic 小型轿车。
How to replace a wing mirror?
How do you replace the passenger's side wing mirror for a honda civic?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Honda Civic, here is what the manual says:"
Power Mirror/Manual Mirror Replacement
1. Lower the door glass fully.
2. Carefully pry out the mirror mount cover (A) by hand in the sequence shown.
3. On power mirror model: Disconnect the connector (A).
4. While holding the mirror, remove the nuts securing the mirror, and remove the mirror
(manual mirror model).
5. On power mirror model: While holding the mirror, push out the connector clip (A),
and remove the mirror (B). Take care not to scratch the door.
6. Install the mirror in the reverse order of removal, and make sure the connector is plugged in properly (power mirror model)."
Hope this helps, good luck.
这个答案有帮助吗?
得分 3
3条评论:
On my 2004 Civic EX, the door panel obstructs access to the lower hex nuts.
由完成的
@mlsmsw have you tried to remove the door panel?
由完成的
I can see that the door panel must be removed. My point is that the instructions given in this post do not apply to my vehicle, and I am puzzled that the post references all seventh generation civics when clearly that is not the case.
由完成的
添加一条评论
添加你的答案
Honda Civic 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 8,064
