跳转到主内容
Also known as Samsung Galaxy Note 4G, Samsung SGH-I717, Samsung Galaxy Note LTE released in January of 2012.
36 个问题 查看全部
Cracked Screen Replacement Question
I have a Samsung Galaxy Note and I cracked the screen. To replace the screen, I ordered a screen replacement but when I went to the ifixit store, they said I also need a LCD Screen. What is the difference between the screen I got and the LCD screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Did you buy just the glass or the full screen assembly ..
If just the glass then this is a very very difficult repair you would have to have experiance in what you are doing the full assembly is really expensive but much easier to fit
这个答案有帮助吗?
得分 1
添加一条评论
dishayush12, you did not give us enough information to tell you that. It sounds like you either only have glass/digitizer or only the LCD. I suggest that you return whatever you purchased and get a complete assembly. Yes, it is more expensive, but you will have the benefit of a better fit and ease of assembly. By using this guide, you can do the repair yourself. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
The top glass is what you touch.
The digitizer is under the glass and is responsible for the touch function.
The LCD is under that and is the screen that you see.
All three are factory-fused together into one assembly. I just replaced one a few days ago. All you're doing is taking the damaged assembly off, moving the internal parts to the new assembly and reassembling.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dishayush12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 300
