跳转到主内容
加入维修社区 - 创建账户
Dell Dimension 8300 是一款 2003 年推出的高端台式机。它支持 Socket 478 处理器,并配备了 4 GB DDR2 RAM。
How to replace the fan?
How do I replace the cooling fan?
Can anyone recommend where to get an original fan or a compatible replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Delta Mike, download the service manual from here. you did not tell us if you are referring to the case fan, the PSU fan or the fan in the heatshroud for your CPU. If it is the CPU fan then all you have to do is to open the case, lift the shroud that covers the processor and remove the fan. Follow the power lead to the motherboard and remove the connector. If you look at the fan you should find some release tabs that lock the fan in place. Press the tab and it should then easily pull away. as to where to purchase it, that will depend on your geographical location. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Sorry not to reply sooner. My new fan is working perfectly thanks, DM.
由完成的
添加一条评论
添加你的答案
Delta Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 896
