跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / 2013 年末 / 3.2 及 3.4 GHz Core i5 或 3.5 GHz Core i7 处理器,ID 为 iMac14,2
Upgrade HDD to SSD
I know I can't add the PCIe SSD right now, but If I just want to swap the 1tb HDD for a SSD is it a big deal? I've read, you need the thermal sensor... Has anyone done this? Should I just take it back and get A Imac with fusion drive and update the PCIe later when OWC figures it out? I've got the ifixit kit and samsung pro ssd and I'm ready to go but I just wanted some opinions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
You might want to consider an external Thunderbolt enclosure this this: http://www.amazon.com/Seagate-Backup-Por...
or this one: http://www.amazon.com/Delock-External-SA...
这个答案有帮助吗?
得分 0
4条评论:
I may not know what I'm talking about but won't that defeat the point? Won't the connection be slower then an SSD connected to a SATA III connection?
完成的
Apple thinks it's so fast that you can't even add internal storage on the new mac Pro. It appears to be 4 times faster than Firewire 800. Take a look at the speed test using the various connections for an idea of just how fast Thunderbolt is: https://www.youtube.com/watch?v=sM2eGiJa... This video using an external SSD vs an internal SATA blew me away: https://www.youtube.com/watch?v=cW8Czra3...
完成的
Take at look at this one, I've convinced myself to go with a Thunderbolt external myself. I like that Seagate one as I can just slap a drive into it.
http://www.diy-review.com/EAk8SHowToK-oU...
完成的
So in the first video he gets read / write speeds of 170 / 180 using external SSD. I wish I could compare this against a internal SSD but I can't find anything. My work macbook pro, three weeks old, has a 500g PCIe SSD so I tested that using the same software. I got 415 / 418 http://imgur.com/VIQZzX5
I think I'm just going to take it back and get the 500g or 256g SSD instead. You can't beat those speeds. I should have just ordered it with an SSD in the first place.
完成的
添加一条评论
The first linked Thunderbolt enclosure, the Seagate Backup Plus Portable Thunderbolt Adapter, is limited to ~320 MB/s read speed and ~380 MB/s write speed.
For me, this was much faster than the base 1TB 7200RPM HDD; however, I bought the brand new Samsung 850 Pro, which is rated roughly 550 MB/s read and write speeds.
So, keep those limits in mind when buying a thunderbolt adapter.
I cannot comment on the Delock.
I read that the Lacie Thunderbolt drive had a much faster I/O limit, and one just removes the original Lacie HDD included inside the enclosure.
I'm researching now wether or not I can just remove the included 1TB HDD and replace it with my 2.5" SSD with the appropriate 2.5" to 3.5" bracket adapter.
I'll update here.
这个答案有帮助吗?
得分 0
添加一条评论
I’ve replaced the HDD with a Crucial 1TB MX500 SSD using the guide and didn’t run into any issues. The whole thing with the temperature sensor didn’t give me any issues. I’ve heard it all from fan being too loud or the fan not turning off at all. I did not have this experience and it’s been 7 months going strong.
这个答案有帮助吗?
得分 0
1条评论:
Your lucky! The Late 2013 with the Mojave firmware update don't need the thermal sensor unit. Apple added the updated S.M.A.R.T. services. Older drives will still need the thermal sensor.
完成的
添加一条评论
添加你的答案
computerartmusic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 4,431
