跳转到主内容
加入维修社区 - 创建账户
一款 Braun 5491 型剃须刀,与 7570、7564、7664 和 7690 型号有许多相似之处。
cannot get it to turn off
it has 3 options to operate . it will operate on all 33 but will not come down to off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
This might help: Braun Shaver Model 7680 电池更换
这个答案有帮助吗?
得分 2
添加一条评论
Open the case as per tutorial to change the battery. I had similar issue but just not turning on, case was full of hair which prevented the correct operation.
这个答案有帮助吗?
得分 0
添加一条评论
The slider switch on mine has failed too. It jams in one or two 'up' positions that make no difference. Mine is the Braun 7505, but essentially the same as many others. YouTube has one video on the topic, solving the problem with a hammer. Unhelpful. :-/
Anyone tackled the sliding switch problem? Certainly not a battery issue.
Thx.
这个答案有帮助吗?
得分 0
1条评论:
@ardwych see if this gets you to where you need to be with that switch.
完成的
添加一条评论
添加你的答案
Harry 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 30
总计 7,588
