How can I my change battery
hello
I have a htc one(m8)and i live in Iran and here htc dosent have any Representation how can i change my battery please help me .
thank you.
The HTC One M8 battery is irremovable and bury underneath the motherboard, so if you want to replace a new one, you have to tear down the phone. You need to separate the M8 screen from front housing, then disassemble the battery. Here is step-by-step tutorial on how to change a HTC One M8 battery for your reference. http://www.etradesupply.com/blog/fix-a-c...
这个答案有帮助吗?
hai have some problem with my htcm m8 when i plug the charger en wont to turn it on ti cane if i plug the charger the batery icon show en stay dear anr a yellow light blinkin all the time
这个答案有帮助吗?
Unfortunately for you the HTC One is probably the worst phone to repair ever made. HTC know the phone is so bad they will even repair your screen one time only
这个答案有帮助吗?
Battery replacement led to the right side alignment being off enough to not allow right margin keys to operate. Example, the "0" key would not work. Also, can demonstrate playing Spyder Solitaire. If upright, the right side columns are immovable. Had to uninstall Swype. Even though I have a paid version, it totally bogs down and stalls the htc 1 m8 after battery replacement. Intermittantly, keys stall in going forward or backward through programs. Will I be able to handle this for another two years? Hmmm.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 37,498
