跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
How can I my change battery
hello
I have a htc one(m8)and i live in Iran and here htc dosent have any Representation how can i change my battery please help me .
thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
alireza, even so not a guide, the teardown on here will show you what you are up against. It is a bear to open and to work on, not easy. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
The HTC One M8 battery is irremovable and bury underneath the motherboard, so if you want to replace a new one, you have to tear down the phone. You need to separate the M8 screen from front housing, then disassemble the battery. Here is step-by-step tutorial on how to change a HTC One M8 battery for your reference. http://www.etradesupply.com/blog/fix-a-c...
这个答案有帮助吗?
得分 0
添加一条评论
hai have some problem with my htcm m8 when i plug the charger en wont to turn it on ti cane if i plug the charger the batery icon show en stay dear anr a yellow light blinkin all the time
这个答案有帮助吗?
得分 0
添加一条评论
Unfortunately for you the HTC One is probably the worst phone to repair ever made. HTC know the phone is so bad they will even repair your screen one time only
这个答案有帮助吗?
得分 0
添加一条评论
Battery replacement led to the right side alignment being off enough to not allow right margin keys to operate. Example, the "0" key would not work. Also, can demonstrate playing Spyder Solitaire. If upright, the right side columns are immovable. Had to uninstall Swype. Even though I have a paid version, it totally bogs down and stalls the htc 1 m8 after battery replacement. Intermittantly, keys stall in going forward or backward through programs. Will I be able to handle this for another two years? Hmmm.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alireza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 37,606
