跳转到主内容
Repair and disassembly guides and support for dish washing appliances.
707 个问题 查看全部
Is there any way to fix or replace bent/broken dishwasher door hinges?
I have a Maytag dishwasher. Today my son decided to be a chef. Needless to say when mama says 1 drop of water and shut the dishwasher... well a skillet with really hot oil, and a handful of water later...
Hot oil splashing, my sons quick retreat ended up with him sitting on the open door of my dishwasher.
Now I'm sure Ive got half of y'all thinking "that's what you get for leaving your kid in the kitchen..."
Well my "kid" is 19yrs old, and 205lbs. and fiercely independent, aka "leave me alone, Im not a kid..." In our situation not only can we not afford a new dishwasher, we cant afford for Dad to find out. Any ideas, suggestions, help would be appreciated. Thanks!
Sincerely, hand washing Mama. =)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Carlita Barton, what model is your dishwasher?
完成的
MDBH969AWS1... Sorry, thought I included that
完成的
We looked up just replacing the door, but not only too expensive, but Im not sure if I can do the work myself, as all the electrical work. All my functions seem undamaged.I just ran a lil test though... no more water tight seal.... =(
完成的
Are the hinges bent or are they broken. A few pictures might be useful.
完成的
添加一条评论
1个答案
已选择的解决方案
Carlita Barton, the door hinges are available at places like this Not cheap:-( To replace the hinges, disconnect the door springs, remove the outer side trim on the door. There should be three Torx head screws on each side of the door frame. remove those. Pull hinge and bracket with studs out of weld bracket
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Carlita Barton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 41
总计 13,246
