跳转到主内容
加入维修社区 - 创建账户
一款由 Micromax Mobile 于 2013 年发布的平板手机。
Recover data from A240 internal memory
My phone is not getting switched on. i tried many things
power btton+ low volume key etc.
service centre have said to rplace the motherboard.
i need my data badly from internal memory. service centre is not helping. need some one immediate help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Data is proprietary (you won't be able to read it). If you can pull the SSD the phone center should be able to mount it in a new phone. If not go up the line until you find someone who can help you.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
vib, the data is stored on t\some hardwired NAND memory chip. Unless you can build a NAND reader and have the software to access the chip, there is no way you can get to the data. Some data recovery centers do have that equipment, but it is very costly to use their services. Sorry, but a normal DIY'er and normal repair shop will not have access to that method. Hope this helps, good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vib 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 1,202
