跳转到主内容
加入维修社区 - 创建账户
惠普推出的热门笔记本电脑。尽管有多种配置,但该系列所有机型的外形基本一致。G60 后面的数字表示该笔记本电脑的出厂规格以及销售渠道。
Checkered screen on G60
Hi, when I start to use my HP G60, the screen develops into a uniformed, hounds-tooth check. Any ideas? George
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
George, try to start it in safe mode, check the display with a lower resolution. Reinstall your video driver. Should that yield no change, open your laptop and check to make sure that all your cable, in particular the LVDS is properly seated. Install an external display and see if that shows the same pattern. If it does, and it is most likely, you are having a GPU failure. What that means is that you'r GPU shows solder fractures. This can only be repaired by either a reflow, which will be temporary, or by a more permanent reball of the GPU. Hope this helps, good luck. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 295
