跳转到主内容
The TI-36X Pro is a scientific calculator manufactured in 2011 by Texas Instruments, Inc. It features a solar cell and backup battery for more memory storage.
Why don't the buttons on my calculator work?
When I press the buttons on my TI-36X, nothing appears on the display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
Kevin Rangel, does your calculator turn on at all?
完成的
I hqve this problem also.
it remain on and no button are working .after sometimes it is off.i tried several times but the problem remains same.please guide me to solve thus issue
完成的
添加一条评论
5个答案
Check if any buttons are stuck beneath the casing. This may prevent your calculator from responding when you press a button. If no buttons are stuck, reset the calculator by pressing the reset button on the back of the calculator with a pen. If none of these steps work, go to our TI-36X Pro Troubleshooting Guide
这个答案有帮助吗?
得分 0
2条评论:
not helpful... none of these work
完成的
where is the reset button
完成的
添加一条评论
Yes, thank you so much! Resetting my calculator corrected the problem.
这个答案有帮助吗?
得分 0
1条评论:
where is the reset button?
完成的
添加一条评论
Everything about my calculator works perfectly except there are no numbers on the keypad. I have to try to remember where the numbers are at when I am typing because there is nothing there. What is wrong with my calculator?
这个答案有帮助吗?
得分 0
添加一条评论
My calculator can’t on..can you tell me the factor why it can’t on?
这个答案有帮助吗?
得分 0
添加一条评论
so my calculator won’t work and it just shows on the very top corner error and the number I type in barley shows
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Rangel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 16
总计 14,339
