跳转到主内容
Spilt soda on keyboard/Wont power on?
Computer still went on after spill but after about 1/2hr When I would type all that would type was /////////////////. So I turned it off till morning, then it wouldn't turn on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You damaged your keyboard at least, maybe logic board at most. Look at the tags at right for all needed to repair a soda spill.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
添加一条评论
In the future, be sure to turn off your computer immediately if it comes in contact with liquid. I stupidly kicked over a glass of water and it poured straight into the back of one of my 2008 aluminum MacBooks, which was closed at the time but woke up when water hit it (apple started glowing). I quickly ripped of the back case and because of the beautiful internals of the unibody generation was able to quickly remove the logic board, drying everything before there was any risk of corrosion. Computer still works fine to this day, three years later. The longer you wait, the worse the damage becomes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
carusich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 154
