跳转到主内容
加入维修社区 - 创建账户
Iconia A110 是宏碁(Acer)于 2012 年 10 月发布的安卓平板电脑。它配备了 MicroSD 卡槽、HDMI 接口、7 英寸多点触摸屏以及一颗 200 万像素的前置摄像头。
Why is my touchscreen unresponsive?
The problem is my touchscreen will not respond completely. For instance, when I try to click a specific app on the home screen, it opens an entirely different app. On top of this, the screen is starting to turn black on certain parts of the screen. Hopefully I can replace the screen if that is even an option.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Kyle, either your Acer Iconia A110 is really beat up or you are working on a student project;-) "a specific app on the home screen, it opens an entirely different app." is usually caused by a bad digitizer, and " starting to turn black on certain parts of the screen." is a good indication that your LCD has failed. Anyhow, here is a decent teardown that you can use to replace your display assembly and your digitizer. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
添加一条评论
My Acer is not responding. When I went to turn it on it is stuck with the picture of a little robot with his belly open and a red triangle. in the left hand corner it is written Android system recovery <3e> acer Cloud / lost .GIR ... I have tried to put a paper clip in te top but nothing is working . I need help!! Susan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 2,075
