跳转到主内容
所有的苹果便携式平板电脑的全面维修手册。维修过程可能需要加热以及细心的撬动。
5769 个问题 查看全部
Can an iPad screen spontaneously crack after replacement?
I work at a computer repair shop, we do heaps of iPad screen replacements. Have had a customer come back after having their screen replaced. They claim they left it on a table and came back a couple hours later to a cracked screen. Has anyone else had this issue? Trying to work out if the customer dropped it and is lying to me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
12个答案
已选择的解决方案
Lauren Curry, had something similar happen due to some stress from the case. As a business person I would suggest that you take the customers word for it. Lets face it, there are always three sides to any story., theirs, yours and then the real story. Does one really want to lo lose customers of this. I'd think the smart thing to do is to replace it once more. Just my 2cents.
这个答案有帮助吗?
得分 6
2条评论:
It also happened to me. Right after I had it fixed by and I did not drop it. It was in my purse (I've carried it in there for 4 years and never had a break), and I opened my purse to get my phone and I found it cracked again. I think these shops are using materials that are cheap (probably from China) and it breaks immediately regardless of what you do or how careful you are. These phones cost so much, they should last longer and be more durable.
完成的
I had the same problem. I had my screen replaced. I took it from the shop. It has a strong cover. After four days I left it on the table went for three minutes went and saw the screen cracked. The case haa a hard cover. After it cracked it never respond. The screen freeze.
完成的
添加一条评论
It is possible in theory.
The glass may be improperly made so internal tension is not balanced, or the case is slightly bent or installation was off so the glass is taking too much stress. Or all above happened at the same time.
It is very rare, though. Apple warrants single fracture on the glass, no questions asked.
这个答案有帮助吗?
得分 3
1条评论:
It’s not rare,it’s called a bent housing.
And then there’s temperature fluctuation cracks as well.
完成的
添加一条评论
My husband suffered the same loss today, our issue with Apple's are the screen is the most likely part to be damaged. Normally when you break something, you go out and by a new one. But in this case, Apple charges so much is because they are NOT replacing the screen, they are replacing the device…we also don’t get any solution for this problem can anybody help???
这个答案有帮助吗?
得分 1
1条评论:
With iPads always get AppleCare for $69 each repair is $49.00.
And you’re right they only offer something called an out of warranty replacement where you trade in and pay.This is not useful for a cracked screen though because it’s a ripoff your better off WAYYYY better off selling the cracked one and buying another you will save a lot$$$
The only time that out of warranty replacement is a good bet is when you have a dead device.
You can literally crush an iPad with a truck roll it up like a joint and trade it in lol
完成的
添加一条评论
Just happened to us as well. Had the screen repaired, all working well that night & in the morning a hairline crack had appeared & the screen/keys jump.
这个答案有帮助吗?
得分 1
1条评论:
It also happened to me. Right after I had it fixed by and I did not drop it. It was in my purse (I've carried it in there for 4 years and never had a break), and I opened my purse to get my phone and I found it cracked again. I think these shops are using materials that are cheap (probably from China) and it breaks immediately regardless of what you do or how careful you are. These phones cost so much, they should last longer and be more durable. Of course, the shop owner thinks I dropped the phone so they won't fix it without me paying again.
完成的
添加一条评论
The same thing happened to me, but a massive hair line crack going all the way across my iPad mini, (when screen is horizontal) not impressed at all...
这个答案有帮助吗?
得分 0
2条评论:
Was this after a repair?
完成的
It’s because the body is slightly bent don’t believe me?
Put it on a flat surface and look for a variation in the structure youll see it if not the glass was overheated during the adhesion process.
Basically.
完成的
添加一条评论
Yes same thing happened to me and now the iPad is difunctional. Will replacing the screen yet again cure it?
Anyone know why it keeps cracking?
Roger Riverside
这个答案有帮助吗?
得分 0
添加一条评论
This happened to me as well. I had an iPhone 6 screen replaced last week and no problems in the first two days. The third day I left it in the passenger seat of my car for a road trip and checked it about an hour into the trip and found several deep breaks in the glass coming from the top corner that were not there at the beginning of the trip and it had not been dropped. It made me wonder if replacement glass isn't the same quality as the original screen or if installation made the screens prone to breaking without contact.
这个答案有帮助吗?
得分 0
3条评论:
The same happened to me on my ipad. Charging takes a king time and itvdoes bot last as long
完成的
It also happened to me. 6S Plus, right after I had it fixed by and I did not drop it. It was in my purse (I've carried it in there for 4 years and never had a break), and I opened my purse to get my phone and I found it cracked again. I think these shops are using materials that are cheap (probably from China) and it breaks immediately regardless of what you do or how careful you are. These phones cost so much, they should last longer and be more durable. Of course, the shop owner thinks I dropped the phone so they won't fix it without me paying again. Shysters using cheap materials and then blaming the customer. '
完成的
Read my responses above
完成的
添加一条评论
Same thing here, picked it up after using it last night and a hairline crack 30mm to the right of the home button extending at 45 degrees to the left side about 60mm up, it has always been in a case ?
这个答案有帮助吗?
得分 0
添加一条评论
This also happened to me. Unreal
这个答案有帮助吗?
得分 0
2条评论:
Read my response above
完成的
Me too just hapoened. I had ot fixed 4 days ago and had it in a case. Opened it today to finally use it and cracked all through middle
完成的
添加一条评论
Yes same thing happened to my sons iPad screens. We got it repaired the first time, and then he said cracks appeared across screen 2 days later. It kept getting worse until unusable. Got it fixed and then it happened again a few weeks but worse, and no usable touchscreen. Now about to take it for third round. Nuts.
这个答案有帮助吗?
得分 0
添加一条评论
Same thing happened to me. Had my screen on IPhone 7 replaced under a warranty. A couple of days after, I noticed a hairline crack in the screen. I didn’t drop it or put any pressure on it. Had basic usage- in and out of purse.
这个答案有帮助吗?
得分 0
添加一条评论
I just bought an iPad Pro refurbished on Amazon and 3 months later a moon shaped crack appeared on the right corner of my screen. No impact points…its under the glass screen protector I bought. There was nothing wrong with it this morning. I was playing pokemon go on it for 4 hrs and looked up and noticed it just appeared. It's very noticeable. I had it in my lap the entire time and am shocked and disappointed in the quality that something like this could even happen.
这个答案有帮助吗?
得分 0
1条评论:
Same thing happened to me, brand new ipad Air2, left it on the bookshelf 'flat' next evening picked it up and there was an elliptical crack in the left hand corner, started just to the left of the button and finished 70mm up on the left hand side. I examined the bottom edge of the glass with a jewellers lupe and it was far from smooth, lots of tiny nicks, I reckon its a design fault, I've heard other people have had exactly the same problem !
完成的
添加一条评论
添加你的答案
Lauren Curry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 59
总计 16,737
