跳转到主内容
加入维修社区 - 创建账户
维修你的汽车或卡车上的扬声器、立体声音响、主机和 CD 播放器。
vauxhall meriva radio code
i need a code for my 2004 meriva
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
5条评论
I get SAFE but then it shows 6 instead of 10 ? H-E-L-P !
完成的
You can get a vauxhall radio code here: https://radiocodevault.com/vauxhall/
完成的
I get safe it show 7 instead of 10
完成的
كود ٢٤ في سيارة فوكسيل ميريفا ٢٠١١
完成的
!!! Please !!! HELP !!! Need audio code for OPEL MERIVA, serial number is GM020531818417. Send in mail: pitomiandjeo@gmail.com Thank you!
完成的
添加一条评论
1个答案
已选择的解决方案
gareth, if you do not have a code, you may want to try this site. If you do have a code try this:"
Entering code into stereo:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
INsP message:-
Ignition Off
Hold Trip Reset In (keep held in)
Press brake pedal (and keep pressed)
Turn on Ignition
Still Hold Trip Reset and brake pedal for approx 10 seconds, the INSP should change.
release brake and trip reset.
switch off ignition
switch on ignition and check. " hope this helps, good luck.
这个答案有帮助吗?
得分 1
4条评论:
Where is trip reset
完成的
My radio show safe7 not ten
完成的
My is Siemens 2005 vdi
完成的
My radio show 9 safe
完成的
添加一条评论
添加你的答案
gareth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 39
总计 34,518
