跳转到主内容
加入维修社区 - 创建账户
一款 HP 于 2011 年推出的平板电脑,运行 webOS 平台。配备 9.7 英寸显示屏,提供 16 GB 或 32 GB 版本。维修过程直观,但需要时间和耐心。
bottom of touchscreen not responding to touch
The bottom 1/2" or so is very unresponsive. It takes multiple taps to get a reaction. The rest of the screen appears to operate properly. What's wrong? Is there anything that can be done to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Traveld, this is usually caused by a defective digitizer or digitizer control board. Of course you always want to try a restore and factory reset first (you may lose all your data) and see if that fixes it. Most likely you will have to replace the control board or digitizer. Start with the cheaper part first:-) Here are all the guides you use for the repair. The parts are readily available. Hope this helps, good luck
这个答案有帮助吗?
得分 0
1条评论:
I have been trying to doctor, but have run into a road block. I get part way through the process, but it stalls right after the instruction to connect the TP to the computer. Nothing happens after that step so I am unable to complete the doctoring route.
Is it possible to replace defective parts on the TP? What is the source?
Thanks
由完成的
添加一条评论
Well I myself am 13 but I'm glad to know at least why parts of the screen on my PC doesn't respond even if I can't fix it so thanks anyways. It was $2000 when I got it and it still operates like a PC without a touchscreen should when you first get it only this thing is about 6 - 7 years old.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem with an Ipad 2. Replacing the digitizer resolved it. The digitizer connection was not making good contact.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Traveld 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,660
