跳转到主内容
加入维修社区 - 创建账户
德州仪器于 1996 年发布的一款热门图形计算器。
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
由完成的
添加一条评论
2个答案
已选择的解决方案
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
这个答案有帮助吗?
得分 10
8条评论:
Holy $@$* you just saved my life
由完成的
thank you so much
由完成的
Thanks! That worked great
由完成的
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
由完成的
Just reset the calculator!!
由完成的
显示更多的3条评论
添加一条评论
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
这个答案有帮助吗?
得分 2
1条评论:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
由完成的
添加一条评论
添加你的答案
Janessa 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 43
总计 25,950
