跳转到主内容
加入维修社区 - 创建账户
Jeep Grand Cherokee 在 1999 年款进行了重新设计;2000 年款的改动极小。该型号也被称为 Jeep WJ。
Steering wheel column lock
How do you repair a bad or bent steering column lock?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Cliff Corriveau, looks like you will have to replace the ignition lock. Here is what the service manual says:
"WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, REFER TO 8M - PASSIVE RESTRAINT SYSTEMS BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.IGNITION SWITCH REMOVAL
The ignition key must be in the key cylinder for
cylinder removal. The key cylinder must be removed
first before removing ignition switch.
(1) Remove key cylinder. Refer to previous steps.
(2) Remove lower steering column cover screws and remove cover (Fig. 19).
(3) Remove ignition switch mounting screw (Fig.17). Use tamper proof torx bit to remove the screw.
(4) Using a small screwdriver, push on locking tab (Fig. 15) and remove switch from steering column.
(5) Disconnect two electrical connectors at rear of ignition switch (Fig. 17).
IGNITION SWITCH INSTALLATION
The ignition key must be in the key cylinder for cylinder removal. The key cylinder must be removed first before removing ignition switch.
(1) Before installing ignition switch, rotate the slot in the switch to the ON position (Fig. 16).
(2) Connect two electrical connectors to rear of ignition switch. Make sure that locking tabs are fully seated into wiring connectors.
(3) Position switch to column and install tamper proof screw. Tighten screw to 3 N·m (26 in. lbs.).
(4) Install steering column lower cover."
Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
I wish you had posted the size of the tamper proof screw :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cliff Corriveau 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 8,984
