跳转到主内容
加入维修社区 - 创建账户
Game Boy 于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
Original Gameboy will not turn on.
I found an original Game Boy that i haven't play in a long time. I have added new batteries and turned it on but nothing, not even the red light will turn on. I haven't opened the console yet to check what may be wrong. I do not want this console to go to waste. What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
已选择的解决方案
ross, the very first thing you want to do is to clean the battery contacts. Make sure they have not corroded to badly. If those are okay, you will have to disassemble your GB and take a look at the components. You could try and clean it with some isopropyl alcohol and carefully check to see if there is anything obviously corroded etc. But until you have it apart, anything will only be a guess. Use these guides to help you with taking it apart. Hope this helps, good luck.
这个答案有帮助吗?
得分 6
3条评论:
@oldturkey03 what do you do if it is corroded badly? I have come across an old DMG-01 which one pair of contacts is badly corroded. Thanks in advance.
完成的
@richielegend depends on the damage etc. We would have to see that. Cleaning the board and possibly repairing damaged traces might be a fix. Big depends on what this all looks like
完成的
The contacts are on a separate piece. Two contacts for two batteries. But what the contacts are on is a small plate. That's has corrosion, but I only have to try to clean contacts itself. Not sure if I can take the two contacts out. It snaps into place
完成的
添加一条评论
Hello. Have the same problem and fix it with contact spray to power switch. But first you got to unscrow six scrows of game boy shel to spray directly to switch. Sorry for my english. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
One thing I always do is use the DMG Game Boy DC adapter and see if it turns on that way, if it does then you will need to clean the battery contacts, if it does not power on with the DC adapter then the Game Boy is pretty much beyond repair, I hope this was helpful.
这个答案有帮助吗?
得分 0
2条评论:
Well I don't have the adapter
完成的
Try picking off the corrosion first, check the board to see where the corrosion spread
完成的
添加一条评论
添加你的答案
ross 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 51
过去 30 天: 231
总计 38,664
