跳转到主内容
加入维修社区 - 创建账户
型号 MD2614u / AMD Turion X2-64 2.1GHz 双核处理器
How does one replace the hard drive?
My Gateway MD2614u will not power on and I was informed that it may be a hard drive issue. Can anyone supply a tutorial or walk through on how to replace the hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Siri, on the bottom of your Gateway laptop, you'll find the hard drive door to access the hard drive. Here you should be able to either pull the hard drive out with the caddy. It may be using some screws that hold it in place. Once you remove the HDD cover you will see how it is fastened. It is actually a pretty straight forward task, and should be very similar to this one. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Thank you!!!
由完成的 分享
添加一条评论
添加你的答案
Siri 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 9
过去 30 天: 20
总计 414
