跳转到主内容
Android-based handheld game console with both touchscreen and gamepad input capabilities, released by Nvidia in July of 2013. Initially dubbed simply "Nvidia Shield," now known as Shield Portable to differentiate it from other Shield products.
Broken Micro usb port
How would some one go about fixing the micro usb port that has broken, it has become separated from the motherboard of the device and might have to be soldiered back on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
Brendan, where are you with your repair? Have you had a chance to take the device apart? Do you have to tools and know how to solder?
完成的
look you have a broken micro is already broken couse i have one of does and i tuked were i bouthed they say is broken we cannot fix it
完成的
Hi everyone I have same problem and I’m trying to fix it by myself
How do i get a micro usb motherboard schematic
Thank you
完成的
添加一条评论
2个答案
最有帮助的答案
The part appears to be the hirose connector ZX62R-AB-5P.
Micro-B Reverse (top-mount) shell SMT
This is not a trivial replacement. At least for me, the solder between the metal shield of the micro USB connector and the PCB has caused some of the circuit tracing of the USB to peal off. I am not sure if this will limit the current carrying capacity of the connector. Also, there is no way to directly solder the pads under the micro USB. You can solder the 5 pins, the 4 PCB punch through points, but not the larger ground pads under the USB connector - the ones that have partially pealed free.
Connecting a cable directly or replacing the motherboard might be the two realistic options.
You can see the broken loose 5 finger pins, the 4 mounting holes, and the two solder down pans in the picture below. If you look at the connector, you can see the two partial copper pads. These are torn loose from the motherboard. Hence the connection can not be reliably reestablished.
这个答案有帮助吗?
得分 4
5条评论:
How do u fix that it
happen to my shield
完成的
exactly what happened to ours as well
完成的
mine is same problem
完成的
there is a company up there that fix it, email is below:
labtechmontreal@gmail.com
完成的
same happen to mine, where to find this part, please answer guys
完成的
添加一条评论
Go to nvidia and ask for a replacement motherboard or if they say they can't help open it up and sacrifice an extra long micro USB cable and cut the micro USB plug off the cable and solder the wires attached to the normal USB plug to the motherboard and use a USB pinout to figure out where to solder each wire on the motherboard.
这个答案有帮助吗?
得分 1
1条评论:
+that's an idea. But why not just take it apart and replace the micro USB port. Check with Mouser or Digikey and replace the port properly.
完成的
添加一条评论
添加你的答案
Brendan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 6,070
