跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
no water when I turn on the washer
I turned the washer on and no water was coming into the washer, what do I need to fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Water Inlet Valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Low Water Pressure from House Supply
If the washer fills very slowly, the water pressure from the house might be too low. If the water inlet valve isn't leaking and there are no other symptoms this problem does not need to be corrected.
Have you ever had water to it? Is it freezing where you live?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stacie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 329
