跳转到主内容
加入维修社区 - 创建账户
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
Is there a documentation for the power supply?
I haven't got a power supply for my Power Mac G4 Cube.
Is the 4 pin connector of the power supply documented somewhere so i can rebuild it?
Update
Hi!
Thx for your answer but as i wrote above, i don't have a power supply and therefore don't know a EEE number.
I'm looking for the electrical specs and the pin layout to re-build a power supply by myself.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How can you re-build it if you do not have it? What are you trying to accomplish? Are you trying to build a power supply?
完成的
Sorry, maybe my english is too bad. I intended to build one from scratch.
完成的
添加一条评论
2个答案
已选择的解决方案
PowerMac G4 Cube 205W Power Supply
EEE Code Note: All Apple Power Supplys have a special three digit "EEE" code embedded in the Power Supply serial number which positively identifies the part. Please note that this is the serial number of the Power Supply, NOT the serial number of the machine. The Power Supply serial number is on a tag which has the format "xxxxxxxEEEx". The "EEE" code is the three letters immediately preceding the last digit of the serial number.
What's yours?
UPDATE
661-2455 or 661-2455 R or 661-2455U
email these folks to find out which power supply is needed for your machine
email us at sales@welovemacs.com with your machine serial number
It should cost under $60.00 on eBayhttp://www.ebay.com/itm/Power-Mac-G4-Cub...
or
Powerbookmedic: http://www.powerbookmedic.com/Power-Mac-...
这个答案有帮助吗?
得分 1
2条评论:
Thx, i'll have a look to my S/N, when i'm back @home on the weekend.
To look on ebay: Will it be an issue, that i need an inlet for 230V/50Hz and not for 110V/60Hz? In other words, is the power supply universal for worldwide voltages?
完成的
All Apple power supplies will work on either 110 or 220.
完成的
添加一条评论
kai, the pinout for the 4 connector plug is as follows:
A = +28V
B = +28V
C = Common (or - side of supply)
D = Common (or - side of supply)
the outer shell of the connector is ground.
这个答案有帮助吗?
得分 1
5条评论:
Thx! This is kind of, what i was looking for!
What does "Common (or - side of supply)" mean? (English is not my native language.)
完成的
kai, if you measure i.e. A and C you should get +28V same with B and D. They are common to A and B but not ground, that is provided by the outside of the connector.
完成的
Ah, understand. Thx a lot!
完成的
Do I need to connect the metal surround to anything? Earth or common?
完成的
@smnbldwn the outer shell of the connector is ground (Earth)
完成的
添加一条评论
添加你的答案
kai 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 4,681
