跳转到主内容
vertical lines across screeen of notebook toshiba qosmio
The screen of the desktop is crossed by a number (exactly 14) of vertical lines large about 1 millimeter of different colors.The device works well but the vision with those lines troubles me. Agostino Torre
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
sounds not that great - but let's start with plugging the qosmio to an external monitor to rule the graphics card out.
here is a great comparsion of screen failures - but i think you's is example 2 with more lines.
here are a few guides for the qosmio's
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
This happened to a friend of mine. Try lightly twisting the display frame. If the number of vertical lines changes or if some disappear and new ones appear then you will have to replace the LCD screen.
这个答案有帮助吗?
得分 2
添加一条评论
The graphics chip on the X505 series and a few others tend to overheat and this causes the solder joints on the motherboard to crack and fail. New motherboards are available on ebay. There are also repair services to reflow the solder joints. You might even be able to repair it yourself with a heatgun like people do with RRoD Xboxes but that's probably above your skill level.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
agostino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,371
