跳转到主内容
加入维修社区 - 创建账户
Galaxy 551 是三星于 2010 年发布的一款直板/全键盘 Android 智能手机。可通过型号 GT-i5510 识别。
Phone screen is black
I droped my phone a couple of hours ago in the toilet. I took it out Immediately, dryed it off and let it dry out after I took it apart. I put it back together and it turned on but the touc screen wouldn't work so I took it apart and let it dry a little longer. I put if back together a hour or so later and it turns on but the screen goes black and I can still here the sounds of incoming text messages. How can I fix this??????
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Kalie, treat it just like any other device with water damage. The very first thing you want to do, is to no longer charge your phone, or to try and turn it on. This may lead to further damage. Remove the battery and disassemble your phone. Clean every part, including the connectors on the board as well as on the cabled with 90%+ isopropyl alcohol and a soft brush. Be diligent about it and clean it well. This does not mean to scrub hard, just rinse in alcohol often. Check for any burned looking or missing components.After that reassemble it and re-evaluate.
这个答案有帮助吗?
得分 4
2条评论:
Thanks! Now it turns on but the touch screen won't work! Why?
由完成的 分享
You still want to clean it :-) could be just a shortened digitizer or a shortened touchscreen IC.
由完成的 分享
添加一条评论
此回答最初是针对另一个问题。
Give it to him for repair XD
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kalie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 896
