跳转到主内容
加入维修社区 - 创建账户
一款于 2005 年 9 月 15 日发布的紧凑型数码相机。
" memory is locked"
I have a similar problem with my SD450. What happens is that when I insert a 32gb memory card it always tells me " memory is locked". I've adjusted the little tab on the card but nothing works. ( I can use a lower gb card and it works okay)
John Allen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
John Allen, make sure that you are using an SD card and not an SDHC. also, the camera was tested by Canon with 2GB cards only, so it is possible that your cameras firmware does not read 32GB, that would explain while your camera " can use a lower gb card and it works okay. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 381
