跳转到主内容
加入维修社区 - 创建账户
Compaq CQ57 系列笔记本电脑的支持信息。
to take safe mode off
my pc is in safe mode. cant put back to restore etc. as have to take safe mode off,which i dont know how to helpo please..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
donnahowland try this first :"If it goes right into Safe Mode without giving you the chance to make choices, try to force your own by re-starting, then tapping F8 or what ever key you need, some machines use the Delete or F12 key.
When you get to the screen, use the down arrow key to choose "Boot from last known good Configuration" touch Enter or Return, and see if that helps.
If the machine already goes to that screen select "Last known Good Configuration", and reboot.
2.) Check msconfig. Type/copy/paste msconfig into the Search or Run box (preferred) select General Tab make sure Normal Startup is selected. Then go to Boot Tab, and make sure Safe Boot is not selected.
3.) Try a System Restore" from here. " let us know which OS you are having and for how long this has been going on, and if anything happened to the computer hardware/software that may have precipitated this.
这个答案有帮助吗?
得分 2
添加一条评论
if its windows 8 it will automatically go into Safe mode on 3 failed boots. let it do a simple repair and it should boot backup with no issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
donnahowland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 3,555
