跳转到主内容
加入维修社区 - 创建账户
Tickle Me Elmo 是 Tyco-Preschool 出品的一款儿童玩具,以儿童电视节目《芝麻街》中的角色 Elmo 为原型。它于 1996 年在美国首次推出。
New batteries, doesn't work.
He was working. Changed the batteries and now he doesn't. Am I missing something here? Is there anything I can try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
When was the last time Elmo worked? You checked the batteries, the proper position and checked for corrosion on the battery contacts?
完成的
I fond a plastic bag in the foot of mine why is it there
完成的
I have a 20 year old Elmo the shaker box stopped working, how do I get a new one.
完成的
hey there do you still have the shaker box?
完成的
Mine also does not work after replacing batteries....plz tell me where to get another shaker box
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
Did you replace ALL the batteries?
Instructions
Open the door to the battery compartments on the bottom of Elmo's feet with a Phillips head screwdriver. Remove the old batteries.
2
Place the AA batteries in the battery compartments according to the polarity indicators designated by a (+) and (-) sign.
3
Replace the battery compartment covers. Replace the screws. Set the "On/off" switch on the bottom of Elmo's right foot to "On."
4
Slide the back cover off the activation box. Install the two AAA batteries in the compartment. Place the batteries in the compartment according to the polarity indicators inside the case.
这个答案有帮助吗?
得分 2
8条评论:
do I mash anything to make it start after batteries
完成的
Where is "the back cover off the activation box"? and how do I access it?
Thank you.
Mike D
完成的
Mike, it's on the back. See the diagram here: Where is Location of Elmo's Activation Box Cover?
完成的
I replaced the battery, not working.
完成的
Mine was working fine put in box.....when I took it out put new batteries just wont turn on....tried everything??
完成的
显示更多的3条评论
添加一条评论
I put new batteries the bottom of the feet and still will not work
这个答案有帮助吗?
得分 1
添加一条评论
I can not get my tickel me Elmo to work after installing new batteries.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jean 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 50
总计 16,786
