跳转到主内容
加入维修社区 - 创建账户
2011 年发布 - Core i3-2330M 处理器
Half of the Screen Broken
I dropped the laptop on a carpeted floor. The screen itself did not crack or shatter, but now only the left hand side of the screen works. It is split right down the middle at the webcam. It still has color. It works fine when I hook it up to an external monitor, and other than that there is only a small crack on the cover-corner where it hit the ground. Any help would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Ray, disassemble you laptop and take a look at the connectors. It is possible that you have a torn cable, broken connector or a broken CCFL. If any of that should not work, you may have to replace the LCD. You can get the service manual from here Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
This might be a cable connecting your LCD with laptop board problem. I would recommend you to take it to a local technician and see if replacing that cable can resolve the issue otherwise you have to go for a new LCD.
Good Luck.
这个答案有帮助吗?
得分 0
1条评论:
Hi! I found this website because I have an issue with my dell laptop, half of the screen was not working, I brought it back from the technician because he cannot repair it, also he was trying to order a 40 pins LCD but he mentioned that there's no available, may i know if do you have any suggestions regarding on this because I don't have any idea about laptop issues. Thank you
由完成的
添加一条评论
添加你的答案
Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,222
