跳转到主内容
The Canon PowerShot A4000 IS is a digital camera offering the user 8x zoom, a 28mm wide-angle lens and a 16 megapixel image sensor. This camera can be directly linked to your computer to upload images and HD video.
6 个问题 查看全部
How can I fix my camera's "lens error"?
My Canon A4000 IS went through the washing machine, and after drying it out in rice for a few weeks I tried to turn it on. It makes a fast clicking sound and the screen says, "Lens error. Will shut down automatically. Restart camera."
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Nate, couple of issues that you have going against you. Even so Rice is a great first aid, it will not prevent corrosion damage. I would suggest that you disassemble your camera and clean every part thouroughly with isopropyl alcohol and a soft brush, even the lens. Once properly cleaned, check for any further corrosion and missing components. Do not forget the inside of the connectors. Reassemble your camera and re-evaluate. If it still should not work, it is best to replace the lens. Yes, it can be disassembled, but it is very difficult to find parts for the lens mechanism etc. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 3,546
