跳转到主内容
加入维修社区 - 创建账户
袖珍型 GPS 接收器,配有 4.3 英寸触摸屏和蓝牙功能。
Back removal to replace battery
I would like to remove the back cover on my Go 720 but have had no luck to date. need help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
ron, follow the instructions for a battery replacement, they will show you how to disassemble your Go720. Here is a video on it and here are the written instructions. Hope you will take lots of pictures and create a guide for this ;-) Good Luck.
这个答案有帮助吗?
得分 1
添加一条评论
when trying to open a device first look for any visible screws, then check and see if screws are hidden (under stickers or rubber feet). to check under stickers without removing the sticker just run your finger or a tool over the sticker and see if you find a round dip where a screw will be.
last will be clips under a frame, use a pry tool to lift the edges till you hear the clips pop and release and work your way around. if you dont have a pry tool you can use a butter knife to a small chisel but i recommend something that hard plastic to not scratch or damage anything.
hope this was helpful, good luck and reply back with your results.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,403
