跳转到主内容
加入维修社区 - 创建账户
型号 A1213或A1218,闪存容量:8、16及32GB
Itunes won't connect with my iPod
Hi there so here is my problem, I have an iPod touch first generation and I just reset it, I also downloaded iTunes for my computer *which is an hp laptop that runs on windows 8*, now when I plug my iPod into my computer iTunes comes up and says it cannot connect to this iPod touch? what do i do to fix this issue? btw it does connect to my computer but not to my iPod
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
6条评论
"it does connect to my computer but not to my iPod" do you mean that your iPod is recognized by the computer but not by iTunes?
完成的
I have the same problem but I have a MacBook Pro and it won't connect
完成的
I just installed iTunes 12.5.4.42 on my ASUS Zenbook/Windows 10 system. Same problem. iPod Touch will not connect to iTunes. Called Apple Support - after a half hour on the phone, and trying the oldturkey03 fix, the Apple tech told me that iTunes no longer works with the old iPods - is this true? Do I have to uninstall iTunes and go back to an earlier version?
完成的
I have same issue. It looks like Apple ended all support for this device. You will need the cd to get driver or use an old mac running snow leopard to fix the issue.
完成的
it's a great post admin
https://www.snapseedforpcguide.co/
完成的
显示更多的1条评论
添加一条评论
7个答案
最有帮助的答案
Kendra, the way I understand your question is that the iPod connects to your computer but iTunes does not. If that is so, it is most likely not your dock connector or your cable, and yes, you can try a different USB port. However, I would try with these steps, since it could be a Windows 8 driver issue:"
1. Open Control Panel.
2. Select Hardware and Sound.
3. Select Devices and Printers.
4. Your iPhone or iPod should be displayed in the Unspecified section. Right-click it and select Properties.
5. Select the Hardware tab, then click the Properties button.
6. From the General tab, select the Change settings button.
7. Select the Driver tab, then select Update Driver.
8. Choose Browse my computer for driver software.
9. Select Browse… then navigate to C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers
10. Click Next > Close.
Your Apple device should now be detected successfully within iTunes."
from here. hope this helps, good luck.
这个答案有帮助吗?
得分 16
19条评论:
This was actually more helpful than Apple was.
完成的
This was by far the best help I could find. You fixed my issue. Thank you so much! Better than Apple.
完成的
oldturkey03's solution did the trick for me!! Thanks so much!!
完成的
works like a charm
完成的
you. are. awesome!!!!
完成的
显示更多的14条评论
添加一条评论
@oldturkey03 How you do this on a Mac that does not see an iPhone 3G?
这个答案有帮助吗?
得分 2
3条评论:
@mayer good question.I will try and figure it out if I find my old iPhone 3G I'll give it a try. Easier for me on a Windows machine :-)
完成的
I'll ask this as a new Mac question tomorrow and accept this answer when it will count.
完成的
Great job. Worked perfectly!
完成的
添加一条评论
Here is a direct download of old iTunes directly from Apple.
What you want to do is find an old version around 9 or 10-ish.
Right-click the installer, and select compatibility mode for Windows 7.
Install using Compatibility mode.
Right-Click the iTunes icon and also set that to run with Compatibility mode for Windows 7.
Here is a little about the history of the device.
Original firmware 1.0 had nothing but basic functionality.
The 5 apps such as calculator was a package add-on of $25.
The next firmware update was another $10.
The 3rd and last charged firmware update was $10, and included the $25 5-app package.
I think if you have never purchased those, you can reflash an old firmware, but it will not have the 5-app package.
这个答案有帮助吗?
得分 2
添加一条评论
If you can, try a mac or windows 7 computer. Also, you could have a faulty USB port on your computer. It could also be a problem with the dock connector.
这个答案有帮助吗?
得分 1
添加一条评论
You have to download an older version of itunes. First go to applications and uninstall these programs in the following order:
iTunes
QuickTime
Apple Software Update
Apple Mobile Device Support
Bonjour
Apple Application Support (if you have it)
make sure to remove them in that order. Then, restart your computer. Download the last compatible version here:
64-bit
http://www.filehorse.com/download-itunes...
OR
32-bit
find out what version of windows 8 you have first, 64 bit or 32 bit. Install that one, and restore your ipod
这个答案有帮助吗?
得分 0
添加一条评论
Hi:
After spending most of a day upgrading my PC to Windows 10 Build 1803, 64 Bit, and, in the process, updating iTunes to the Windows app version, I was quite frustrated to learn that almost all of the newer versions of iTunes (after about 12.5, including the app on the Windows Store) will not connect with my iPod 1G. %#*@ shame as the iPod continues to work very reliably. I tried several versions of iTunes and a variety of drivers and other diagnostics. Nothing helped - until I found iTunes 12.2.2 at https://itunes-64-bits.en.uptodown.com/w.... I installed that version (run the downloaded install file As Administrator), and presto! My iPod connected and was fully functional. Yay!!
I tried a lot of different approaches but this is what finally worked for me. I hope it is of some help tom others.
这个答案有帮助吗?
得分 0
2条评论:
PS. Don't forget to turn Auto Update off. Otherwise, you'll get an updated version that won;t work with the iPod 1G. :-)
完成的
Thanks Ron, same boat, exactly what I needed!
完成的
添加一条评论
We have just been speaking with i tunes and they have just told us that second generation is a vintage model so will not be compatable with i tunes 12.1
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kendra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 88
总计 43,107
