跳转到主内容
加入维修社区 - 创建账户
12 英寸显示屏的 PowerBook G4 Aluminum 笔记本电脑。2003 年由 Apple 发布。
Why is the screen dim?
I just took it apart to remove a loose screw in the optical drive and now the screen is dim...did I disconnect something? I am also having trouble getting the keys back on (is it a coincidence that one of the keys I removed was the dimmer key and the other is the brightener key)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
are you saying that you cannot increase brightness because the key is not working?
由完成的
Thanks for the tips, I tried an external keyboard and proved that the problem is not the keyboard. I think I might have tweaked the display cable when I was putting the computer back together or maybe I mixed up some of the screws, could a too long or too short screw cause a problem?
由完成的
DEAR LEMERISE..THE screen is very dark...if I turn it at a particular angle I can see the icons,etc on the screen.
由完成的
12"...I've ordered a new display cable and when I get it i'll recheck all of my screws to make sure they are the right ones in the right places..thanks for your advise
由完成的
添加一条评论
5个答案
已选择的解决方案
You may go to the system preferences display preferences and check if you can modify the brightness from there. If yes then the keyboard has a problem. Try with an external USB keyboard.
这个答案有帮助吗?
得分 2
添加一条评论
try turning up the brightness, also charge your battery, the screen dims when the battery lowers, you could try to check the display cable too.
这个答案有帮助吗?
得分 0
添加一条评论
What is the PowerBook model (speed) ? 12"/15"/17" ?
这个答案有帮助吗?
得分 0
添加一条评论
You still have video in the screen so the new display cable will not solve the problem. From your description it seems to be a lightning problem related to the inverter cable, inverter board or backlight. You say the screen is dim. Is it completely black or there's still light in it ?
这个答案有帮助吗?
得分 0
添加一条评论
If the long screw you are referring to pinches a cable it can cause problems.
only YOU can tell if you put it together properly - why not take it apart and check - that way you also can check if you damaged a wire by routing it incorrectly.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
oliviachas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 2,776
