跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for the Compaq Presario CQ60.
no screen or output
i have a compaq cq60 laptop. the screen just stopped working, no backlight nothing. all the right lights are comming on so i think the laptop is working but no picture. i have tried a new screen and inverter, still nothing. i have connected to my tv via hdmi and to a moniter via i/o port still nothing. any help or suggestions would be appriciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
will buck, ". i have connected to my tv via hdmi and to a moniter via i/o port still nothing." sounds like a bad video card. On this computer, the video card is actually a chipset on the motherboard. You could try an external USB card to see if that works. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
3条评论:
thanks. i will try that first. if that works i know its the chipset on board. maybe i will get out the heatgun and try a reflow of the chip
完成的
It's a possibility :-) Thanks for accepting my answer and good luck to you.
完成的
Problema driver
完成的
添加一条评论
Se lo hai aggiornato a windows 10 è normale. Per prima prova se va in modalità provvisoria e in Gestione dispositivi disinstalla il driver scheda grafica e riavvia. Provvederà windows update, (se lo hai attivato) al corretto aggiornamento. Anche se windows 10 ha già una scheda video già integrata. Se questo non funziona aggiorna il Bios. PC spento tieni premuto contemporaneamente i tasti per 1 secondo (tasto Accensione+Window+B), attendi 40-50 secondi anche qualcosa in più. Se non funziona è un problema di hardware, sulla scheda madre.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
will buck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 1,319
