跳转到主内容
加入维修社区 - 创建账户
Sony Ericsson Xperia Mini Pro SK17i 配备了 3 英寸屏幕、侧滑键盘和可更换电池。于 2011 年 8 月发布。
Backspace is too sensitive :-(
My primary situation:
The keyboard is generally working fine but the backspace only needs a fine touch not a complete depress. That means that it will delete half a line in no time when touched. It is placed slightly lower than the rest of the keys but it still has the "click"-sound and -feeling like the rest of the keyboard.
I got the phone in dec. 2011 and it has been used moderately since then. I'm not a heavy text'er or anything like that.
My question (for a solution):
The SK17i tear down does not fully show the parts of the keyboard. Is there a rubber mat between the keyboards outer skin and the contacts?
Is the contruction similar to that of a remote control?
Will I need a whole new keyboard (it's danish)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Jesper if you are referring to the "domesheet", yes it does have one. You can replace the domesheet, but it sounds like you are needing a new keypad.
The keypad is on the back side of the main board. The domesheet lays over it.
这个答案有帮助吗?
得分 1
4条评论:
What is the PCB shown at the bottom photo?
It could be difficult to find a danish keyboard... :-/
由完成的
I attached an image to the original answer to show that it is the backside of your main board. I did a quick (very quick ;) search and only found a QWERTY keyboard on ebay. A danish one may require a bit more of a search.
由完成的
Danish keyboards have QWERTY-layout too, but we have some extra letters (æøå)... :-)
So I will need a new main board?
由完成的
A new keyboard should work and is probably easier (not meaning easy) than the board. You could try and disassemble it and take a look and see if you can isolate the problem.
由完成的
添加一条评论
I have the same problem with my Xperia Mini Pro, "d" letter in little touch is written cycled again and again. Broken was the dome sheet under keyboard. I have replaced firstly keypad, but all was bad as before, after changing dome sheet is all working now fine :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,024
