跳转到主内容
加入维修社区 - 创建账户
Sony Cyber-shot DSC-W55 于 2007 年初发布。与之前机型的 510 万像素摄像头相比,它升级到了 720 万像素摄像头,并拥有 56 MB 的内置内存。
Flash does not work!
Turned camera on and heard a loud pop. Removed and charged NP-BG1 battery. Reinstalled charged battery, but battery discharged rapidly. Bought new NP-FG1 battery, charged battery, installed battery and got "E91:01 error code with flash symbol flashing on LCD screen. Camera takes pictures, but flash does not flash. I suspect the capacitor blew when the loud pop was heard. Any suggestions?
Where can I buy a replacement capacitor without buying the entire flash unit?
THANKS in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Dick, the error code that you are getting is related to an issue with the flash or light on your camera. There are a two things that may have made that noise, Either your flash bulb, or your flash capacitor. Follow [http://he error code that you are getting is related to an issue with the flash or light on your camera. It's usually just replacing the flash bulb on the camera,|this guide] to either replace the capacitor or the whole assembly. the part numbers are as follows:
1-479-663-31 FLASH UNIT
1-112-819-11 ELECT 97uF 315V Capacitor
you can get it from here
A-1231-877-A ST-133 BOARD, COMPLETE
Hope this helps, good luck.
这个答案有帮助吗?
得分 2
3条评论:
THANKS "oldturkey03", I plan to disassemble the camera and investigate further this week. Dick
完成的
На плате st-133 посмотри контакты конденсатора и детали которая распаяна под лампой . Может и в самом конденсаторе дело ! Тратить надо ...
完成的
сперва саму батарею проверь . а потом дальше ...
完成的
添加一条评论
添加你的答案
Dickie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 18
总计 2,240
