跳转到主内容
加入维修社区 - 创建账户
Nexus S 是由 Google 与三星共同研发的智能手机,也是首款采用 Android 2.3 “姜饼”操作系统的智能手机。
Change faulty USB port
Hi, I have the same problem. I wonder if I can change the USB port? Does anyone have any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Aneta, yes you can:-) Disassemble it by using this guide. Once you have the motherboard separated, unsolder the USB port. You can get replacements from here as well as many other places. This will of course depend on your geographical location. Then you solder the new part to your board, and reassemble. If you are unsure about the soldering, you may try a TV or electronics repair shop. Also some vocational schools are very helpful with that. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aneta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 1,263
