跳转到主内容
Released March 2006, identified by model D620 on the keyboard bezel.
My laptop won't boot up
My laptop screen just went blank and it will no longer boot up how do I resolve this problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
do you get anything? Any lights, any POST beep? Have you tried to remove the battery, the RAM and the AC power and hold the power button down for around 30sec then replace the RAM on at a time to see what you get.
完成的
Iam not a computer person it just says no bootable device I've tried taking out battery
完成的
添加一条评论
2个答案
已选择的解决方案
Here is a link to Dells service guide for your computer. Hope this helps.
ftp://ftp.dell.com/Manuals/all-products/...
这个答案有帮助吗?
得分 2
1条评论:
our laptop d620 is boot up after 1 mint what is solution of this problem
完成的
添加一条评论
If its not booting up and turning on the try to perform a windows repair by following steps:
In case you dont have a disk you can repair windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start
booting from USB).
Step 8- follow the on screen instructions to complete the windows repair. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,356
