跳转到主内容
加入维修社区 - 创建账户
1999 年至 2004 年间生产的第二代北美版 Honda Odyssey 的指南和维修信息。
brake light is out
i have replaced the brake light but it still does not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
When you say you replaced the brake light, what exactly did you replace? The light, the bulbs?
完成的
添加一条评论
4个答案
最有帮助的答案
Anne, check fuse number 47 in the Under-the -hood fuse/relay box for continuity as well as fuse number 9 in the under-dash fuse box. Check your light bulbs, they are dual-filament bulbs (type 7443) 21/5W and are on top of the tailights. Check the Brake Pedal Position Switch, use a multimeter or continuity tester to make sure it is working. If all that is okay, and since both sides are affected, there is a possibility that your Brake Lights failure sensor needs replacement. It should be located at the left rear of the cargo area. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
There is no fuse # 47 for 1999 Odyssey. Is there a different number for that year?
这个答案有帮助吗?
得分 1
1条评论:
The under hood fuse is called STOP on the fuse box cover and in the owner manual. This is the one controls the brake lights and brake switch. (This fuse in All Hondas should be in the under hood fuse box but with different number.)
完成的
添加一条评论
My brake lamp came on my 2000 Honda Odyssey does this mean a bulb is bad? I thought I had a brake problem? Thanks for your help??
这个答案有帮助吗?
得分 0
3条评论:
I have Odessey 2004 and dashboard shows indicaror for "Brake Lamp". Any idea whats the problem?
完成的
Mine too. Any solutions?
完成的
The under hood fuse is called STOP on the fuse box cover and in the owner manual. This is the one control the brake lights and brake switch. (This fuse in All Hondas should be in the under hood fuse box but with different number.)
完成的
添加一条评论
Would a bad brake light sensor cause the STOP fuse to blow? I found that my key interlock switch not working and found this fuse blown, replaced it with another one it blew again the moment I step on the brake.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 44
总计 18,194
