跳转到主内容
加入维修社区 - 创建账户
zd8000 型号,17 英寸宽屏显示器,2.8-3.6 GHz Intel Pentium 4 处理器
Windows 7 upgrade, now sound drivers needed.
I have tried all drivers provided by hp, still no sound.
Can you help me please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
Does your sound card show in device manager? Does it show normal or does it have an exclamation point?
由完成的
添加一条评论
4个答案
已选择的解决方案
Digitale, apparently you are not the only one. Do a Google search on that particular problem. Most of them are resolved by doing a clean install of Win Vista, let all the drivers install, then install win 7 update. Or you can try this, download the HP Compaq nx6125 Notebook PC*-* Conexant AC97 Audio Driver for Microsoft Vista (32-bit) from here Extract but dont install. Go to c:swsetup and rename the 2 files: camc6aud.sys and camc6hal.sys to camcaud.sys and camchal.sys and copy them to c:windowssystem32drivers and restart the laptop.
这个答案有帮助吗?
得分 3
添加一条评论
Hello, My name is Daniel,
You may get the drivers in Windows update, if you have installed a new OS that hasn't been used on your system before then your computer may not be programmed to work with that operating system. This means there will be no drivers available in this case.
这个答案有帮助吗?
得分 0
添加一条评论
Check in the HP web page, may be this page have this drivers...
这个答案有帮助吗?
得分 0
添加一条评论
Hi
http://server88-208-222-62.live-servers.... the same problem finding drivers for the zd8000 pavilion HP laptop that I was upgrading to windows 7. found all the answers and drivers at the link above .
They tell you it can't be done well trust me it can go to the link above to find the drivers you need and more, info ,support and even windows downloads.
I've had my zd8000 since new and paid a big dollar for it and HP ditched us on the drivers to upgrade from xp shame on them. Good luck
这个答案有帮助吗?
得分 0
2条评论:
double check your link, sure looks like SPAM to me....
由完成的
Hi
Seems to work for me , put in the search box on the upper left zd8000 drivers win 7 or try the link below
this page is from the link I sent you first .
I have sent you no spam although this site (Fix-it) atts ads like update your XP good luck with this it helped me out with my zd8000 upgrade to wins 7
由完成的
添加一条评论
添加你的答案
Digitale 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 7,822
