跳转到主内容
加入维修社区 - 创建账户
Kinect 是专为 Xbox 360 设计的一款游戏外设,允许用户通过肢体动作和语言来控制游戏主机。
Two Question About Kinect For Xbox 360?
i have two question about kinect
1- if i connected the kinect for xbox 360 to computer, is there any damage could happned to kinect ??
2- is there any solution or hacking for make kinect for xbox 360 work on computer ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
Is this the same Kinect that you had asked previously about? the one with the burned out chip?
由完成的
yea, my friend give it to someone to fix it and still no answer
由完成的
iam just asking to sure iam right or wrong, i mean what happened to kinect because of me or because of the man who i bought from him the kinect
second i saw videos on youtube about hacking kinect but iam still not sure if that real or fake ???
由完成的
i have another question
is the tools or gears in kinect for xbox 360 is same in kinect for windows and the different is the word on kinect (xbox 360, kinect) ????
由完成的
添加一条评论
3个答案
已选择的解决方案
The kinect is made for the xbox but aswell as the computer, to get it to work simply plug it in and let windows download the correct software and drivers. If it does not install you then need to download the drivers at windows.com.
The kinect for the computer come's with a SDK for scripting code for small games or applications.
I seen someone script a automated turret with it loaded with a nerf gun lol.
这个答案有帮助吗?
得分 2
3条评论:
FF90 thank you
can you give me direct link for drivers ??
由完成的
Drivers - Link
<space> .NET - Link (required to work)
由完成的
thanks for help but iam still confused
由完成的
添加一条评论
最有帮助的答案
FF90 is right, even so that the Kinect for the PC differs somewhat from the xBox Kinect. If you want to try to connect the Xbox Kinect to your computer, check on here for the requirements and software. To get a adpater for the Xbox to PC check on here. Do not expect to find very many games that will support this yet, and most of the software is still custom.Hope this helps, good luck.
这个答案有帮助吗?
得分 4
14条评论:
thank you for help me
由完成的
由完成的
there is no different product version that you can buy for a different platform. its compatible with both platforms on the same device
由完成的
wow specifically says "NOT FOR USE WITH XBOX360" i learn something new everyday, i wonder if i can use the new SDK 1.5 with my original xbox kinect?
由完成的
显示更多的9条评论
添加一条评论
No damage can occur from plugging the Kinect in to your computer, but unless you have the necessary drivers installed, you won't be able to do much.
Please visit OpenNI for information about an open source Kinect platform.
The book Making Things See is a very good resource for getting started with hacking the Kinect.
I personally have been able to write a few small programs to use the functionality of the Kinect to perform other tasks on the computer.
这个答案有帮助吗?
得分 1
1条评论:
i said that to the man who i bought from him kinect but he don't believe me, he said he plugin the adapter in jack and it's working and the damage i'm responsible of it, all i did it i put adapter in jack and connected the cable in usb and no answer from kinect no move no light nothing but the adapter working and and the lamb in cable is lighten but no response from kinect
any way thanks for help and after my kinect is fix and i think it's impossible i will try to connect it again to computer
由完成的
添加一条评论
添加你的答案
Islam Abou Seada 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 2,250
