跳转到主内容
加入维修社区 - 创建账户
Mazda Millenia 是日本汽车制造商马自达(Mazda)在 1993 年至 2002 年间生产的一款行政轿车。
fuel pump fuse location
No power to the fuel pump. relay tested good. where is the fuel pump fuse located on this car?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
johnelmore47, looks like the Millenia has got one. It is a 15 Amp fuse and should be marked engine in the fuse box. It also uses a resistor. Here is what the manual says:
Fuel Pump Control System
System inspection
1. turn the ignition switch to START and check operation of fuel pump relay and fuel pump resistor and relay by listening for their operating sound.
2. If no sound was heard, check the fuel pump relay and duel pump resistor and relay (speed0.
3. If the fuel pump relay and fuel pump resistor and relay(speed) are normal, check voltage at following terminals
ECM terminal 1H (Ignition switch start signal)
ECM terminal 1AF(Fuel pump relay)
ECM terminal 1AJ (fuel pump resistor and relay)
Fuel Pump Relay
Inspection
1. Remove the cruise actuator
2. remove the fuel pump relay.
3. Apply battery positive voltage and check continuity between terminal of the relay by using an ohmmeter
4. If not as specified, replace the fuel pump relay.
Fuel Pump Resistor and relay (Speed)
Inspection
1. Disconnect the fuel pump resistor and relay connector. Measure the resistance between terminals A and B by using an ohmmeter
Specification:0.38-0.42 ohm
2. If not as specified, replace the fuel pump resistor and relay (speed).
Here is the wiring diagram
这个答案有帮助吗?
得分 5
2条评论:
Do u remove the backseat to install the fuel pump on a 2001 Mazda millenia
由完成的
Yes you'll have to.
由完成的
添加一条评论
Which fuse do I check for rear break lights? My lid to fuse box is missing. 1995 929
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
johnelmore47 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 50
总计 37,376
