跳转到主内容
加入维修社区 - 创建账户
Two beeps and black screen.
I have the same problem as Angela but my screen is always black, when I try to reset it (by holding the menu and select button for 6sec) it just powers off and back on but still gives the black screen. Then it beebs 2 times, just like Angela's I suppose. I just tried to reset it via iTunes but it still shows a black screen. I can hear the clicks when I use the click wheel. What do I do ?
Greetz James
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My iPod will not turn on I put it on the changer an it beeps 2 times dose that mean its changing
由完成的
添加一条评论
1个答案
已选择的解决方案
jamesschelfaut, there are a few possibilities, but they all require you to disassemble your iPod. It could be loose ribbon cables, corroded connectors, a bad LCD and/or bad backlight circuit. I would check it in that order. Here are the guides to work on it. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jamesschelfaut 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 43
总计 9,849
