跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Keurig 手柄损坏
手柄破损、开裂,或无法正常向下按压。
需要更换手柄
如果手柄破损或开裂,你可以在线购买更换件。你可以点击此处购买更换手柄。
关于如何更换手柄的步骤,你可以查看我们此处的指南。
Keurig 漏水或漏咖啡
机器顶部或底部有液体渗漏。
Keurig 底部漏水
如果 K-cup 支架开裂,可能会导致水从中漏出。这种情况下需要更换支架。你可以点击此处获取零件。
Keurig 顶部漏水
如果 K-cup 支架未损坏,可能是软管堵塞。你需要拆开 Keurig 的顶部进行检查。如果确实堵塞,需要按照必要的步骤进行疏通。
无法出水或出咖啡
水无法流经 K-cup 并从底部排出。
水溢出,没有流经机器并流出咖啡
如果水或咖啡在 K-cup 支架周围溢出,而不是正常流出,可能是针头未穿透 K-cup,或者 K-cup 支架堵塞。你可以查看我们关于如何更换顶部针头的指南。
水无法进入 K-cup
如果倒入水箱的水无法排出,水就不会到达 K-cup。Keurig 的排水口可能堵塞了。
出水或出咖啡缓慢
咖啡可以流出,但速度比机器刚购买时慢。
顶部针头可能未充分穿透 K-cup
如果出水速度异常缓慢,可能是顶部针头变钝或不干净,你需要清洁或打磨针头。
软管部分堵塞
如果咖啡流出缓慢且顶部针头没有太钝,则可能是你的水管发生了部分堵塞。
水加热不正常
加热元件可能无法工作
加热元件可能已损坏,需要更换。如需更换加热元件,请点击此链接此处
Mark Henein
于02/04/16注册
369 声望
创作了2篇指南
团队
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S17G6
2 名成员
创作了24篇指南
16条评论
Why is it that I signed up with a username and get a message that I am prohibited from viewing the guide?
janthonyartist - 回复 分享
I wrote 2 weeks ago and have not heard, My Keurig is punching too big hole in the top of the K-cup
I need help. I am having to strain my coffee.
Ruby
Ruby - 回复 分享
the coffee is backing up and punching a hole in the middle of the coffee insert
Andy Elliot - 回复 分享
I returned my first machine because it wasn’t working. Saw a review that mentioned that using filtered water from a Brita or Zero Water causes problems with the brewing process. The machine requires some minerals in the water to work properly. This has proven to be true for me. My second machine works fine as long as I use tap water. Accidentally used filtered water and got half a lukewarm cup again. Used tap water worked like a charm. Keurig should put this in their instructions otherwise how would you know.
ck_dash - 回复 分享
Wow - That was exactly my issue as well. Was using demineralized water and was ready to throw the thing out. Used normal water and it runs perfectly.
When I read your comment I thought “there’s no way that could be it!”
chris - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 56
总计 42,112
