跳转到主内容
目录
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Device Will Not Charge or Turn On
Device does not power on when power button is pressed or does not charge while plugged in
Faulty Power Adaptor
Ensure that the charge light is on when the power adaptor is plugged in. If light is not on, then your power adaptor may be faulty. Try wiggling connection to the laptop to see if the charge light will turn on because there may be a bad connection. Check for a bad adaptor by disconnecting the battery and trying to turn the laptop on with the adaptor connected. If the adaptor appears to be in working order, then the battery may need to be replaced.
Faulty Battery
If device only turns on when plugged into power adaptor, then the battery may not be able to hold charge. Follow this guide to replace it.
Keyboard Does Not Function Properly
Certain buttons on keyboard stick or do not type.
Keys Stick When Typing
Ensure that the keyboard is clean. Using a compressed air duster, clean underneath the keys that are sticky. If the problem persists, you may have a faulty keyboard. Follow this video from Lenovo's website on how to replace it.
Keys are Unresponsive
If keys are unresponsive, then you may need to replace the keyboard. Ensure that all device drivers are up to date. If the problem persists, consider replacing the keyboard. Follow this video from Lenovo's website on how to replace it.
Keys are Broken and Missing
If keys are broken or missing, then you will need to replace your keyboard. Follow this video from Lenovo's website on how to replace it.
Device is Overheating or Not Cooling
Your computer will shut off after overheating warning displayed.
Clogged Fan Ventilation
Check fan ventilation on the bottom and rear of the computer for any dust or debris. If clogged, use pressurized air to clean vents.
Faulty CPU Fan
If the air vents are clean and your device is still overheating, you might have a faulty CPU fan or broken heat sink. Follow this guide to replace it.
Windows Crash / Frequent Blue Screen
Device displays windows crash/memory dump message on screen and shuts down.
Operating System Not Updated
Ensure that all drivers are installed/updated correctly if problem is caused when running a specific program or service. Windows 10 will run a diagnostic on itself to resolve any software issues. If the problem persists then consider replacing the RAM module.
Check Drivers for New Hardware
Check the manufacturer's manual for new devices to download or to install new drivers and then run windows normally. If problem persists, RAM Module may be faulty; consider replacing it. Unplug new devices and run windows normally. If problem persists, consider replacing RAM module.
Faulty RAM Modules
If crashes are occasional then the RAM itself may not be faulty, but may have become loose or have a bad connection. Ensure that the module itself is fully seated in the motherboard. Ensure that the module does not appear to be damaged in any way. If crashes occur frequently, then the RAM module should be replaced. Follow this guide to replace it.
Faulty Hard Drive
If crashes are infrequent or occur when loading a specific program, and you have ensured that all drivers and the software itself are up to date, then the issue may be due to a faulty hard drive. Ensure that the hard drive is not damaged in anyway and that it is seated fully in the motherboard. If the problem persists, please follow this guide to replace it.
Windows Does Not Boot
Device turns on but does not launch Windows.
Faulty Hard Drive
If the device turns on and shows the Lenovo logo but does not launch Windows (ie Windows Logo is not shown) then the boot order may be incorrect. Follow the instructions here in order to check the hard drive. If the suggested fixes do not solve the problem, then your hard drive may be faulty. Follow the instructions in this guide to replace it.
团队
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G3
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 5,402
