跳转到主内容
你所需要的
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Samsung Galaxy Buds,应参考我们的维修指南
    最后的想法
    • 外部组件用卡扣固定而不是胶水,使得大部分操作不具破坏性。
    • 普通的撬棒工具和十字螺丝刀就可以完成拆解。
    • 耳机使用的硬币状电池很容易在网络上找到来进行以后可能需要的更换。
    • 充电外壳的电池更换方便,但是可能更难买到。
    • 胶水被用来固定住很多的内部组件,虽然不多而且可以重新用来组装。
    • 打开后,分开胶水固定的部件时小心撬动来避免弄坏脆弱的线缆。
    • 充电外壳里的一些线缆被直接固定在了主板上而不是使用接触垫或连接器。
    可修复性评分
    6
    可修复性10分中得6分
    (10是最容易修复)
由衷感谢以下译者:
en zh
75%
Patrick Zhang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Taylor Dixon
于06/26/18注册
69,690 声望
创作了94篇指南
28条评论
%#*@, I wish you were my friend. I would then buy you a case of beer for you to tear apart my hearing aid and give it a good cleaning.
icomeau - 回复
Someone accidentally washed my charging case…thank God the earbuds weren’t a part of it. However, ever since it refuses to charge my earbuds and I cant find a replacement online. Any ideas?
Mohsin Khan - 回复
You can take it apart and let it all dry out for a little while! If it’s not working after that, you can check eBay for someone selling a working case by itself.
Taylor Dixon -
I accidentally dropped one earbud and it got stepped on and now it won't work, like it doesn't connect or play music, is there a way to repair or do I need a new set?
Gabriel Pulido - 回复
It’s hard to say for sure what exactly broke inside the bud, but if you can find some parts on eBay or somewhere then you can probably bring the bud back to life! The tricky part is finding the parts since the buds are so new.
Taylor Dixon -
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 123
过去 30 天: 620
总计 146,316
