跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Cisco 878 Integrated Services Router,请使用我们的维修手册
  1. Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 步骤 1 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 步骤 1 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 步骤 1 中的图像 3,3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Teardown, Remove top cover: 步骤 2 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove top cover: 步骤 2 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove top cover: 步骤 2 中的图像 3,3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Integrated Services Router Teardown, Remove the three screws on front side: 步骤 3 中的图像 1,2 Cisco 878 Integrated Services Router Teardown, Remove the three screws on front side: 步骤 3 中的图像 2,2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 步骤 4 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 步骤 4 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 步骤 4 中的图像 3,3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
  5. Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 步骤 5 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 步骤 5 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 步骤 5 中的图像 3,3
    • 1. Place your fingers on the levers at the two sides of the slot, and push open.
    • 2. Firmly pull the release lever away from the module until the module pops up.
    • 3. You can then remove the module from the module slot.
  6. Cisco 878 Integrated Services Router Teardown, Remove black and silver screws: 步骤 6 中的图像 1,1
    • 1. Use the Phillips #1 Screwdriver to remove the black screw.
    • 2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
    • You should remove just only one silver screw - the second one is holding just cooling plate.
  7. Cisco 878 Integrated Services Router Teardown, Remove CPU module: 步骤 7 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove CPU module: 步骤 7 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove CPU module: 步骤 7 中的图像 3,3
    • Gently pull the module up to disconnect two connectors underneath.
    • Be careful and don't damage 4-pin connector (marked RED).
  8. Cisco 878 Integrated Services Router Teardown, Remove screws holding motherboard: 步骤 8 中的图像 1,1
    • Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
    • When putting screws back, don't use force - threads are made of plastic!
  9. Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 步骤 9 中的图像 1,3 Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 步骤 9 中的图像 2,3 Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 步骤 9 中的图像 3,3
    • 1. Gently lift up the board to release plastic locks.
    • 2. Gently pull the board away from backside panel (to release metal shielding locks around connectors).
    • 3. Remove board from the case.
  10. Cisco 878 Integrated Services Router Teardown, Teardown complete: 步骤 10 中的图像 1,1
    • Parts and pieces:
    • Top cover
    • Inner metal shield cover
    • Bottom part of case with metal shielding
    • Motherboard
    • SHDSL Filter Module board
    • StrataFlash Memory Module
    • 1 black screw, 1 silver long screw (1 is still on SHDSL Filter Module board), 7 silver screws
  11. Cisco 878 Integrated Services Router Teardown, Motherboard extension slots: 步骤 11 中的图像 1,1
    • mini-PCI slot for WLAN card
    • DRAM socket for additional RAM Memory Module
    • Slot for additional StrataFlash Memory Module (4MB module installed)
    • Two connectors for SHDSL Filter Module board
Jiri Altman
于05/03/16注册
1,488 声望
创作了9篇指南
团队
4k20 Repair Team 4k20 Repair Team 的会员
Community
2 名成员
创作了17篇指南
3条评论
Sorry mate, that's not a CPU board but a SHDSL line filter. CPU is the biggest, center chip (freescale)
karmansan - 回复
Thx for info! I will update my guide accordingly...
Jiri Altman -
is it possible to add wireless capability to this router by installing a wifi card in the empty mini PCI slot?
timber poodle - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 3,511
