跳转到主内容
加入维修社区 - 创建账户
iView-776TPCII Motherboard Replacement
你所需要的
    1. iView-776TPCII Motherboard Replacement, Rear Panel: 步骤 1 中的图像 1,3 iView-776TPCII Motherboard Replacement, Rear Panel: 步骤 1 中的图像 2,3 iView-776TPCII Motherboard Replacement, Rear Panel: 步骤 1 中的图像 3,3
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      询问修复机器人
      添加评论
    2. iView-776TPCII Motherboard Replacement: 步骤 2 中的图像 1,2 iView-776TPCII Motherboard Replacement: 步骤 2 中的图像 2,2
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      询问修复机器人
      添加评论
    1. iView-776TPCII Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      询问修复机器人
      添加评论
    2. iView-776TPCII Motherboard Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      询问修复机器人
      添加评论
    1. iView-776TPCII Motherboard Replacement, Wi-Fi Antenna: 步骤 5 中的图像 1,2 iView-776TPCII Motherboard Replacement, Wi-Fi Antenna: 步骤 5 中的图像 2,2
      • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
      询问修复机器人
      添加评论
    2. iView-776TPCII Motherboard Replacement: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
      • Once heated, use tweezers to pull the wire free from its connection.
      询问修复机器人
      添加评论
    1. iView-776TPCII Motherboard Replacement, Camera Assembly: 步骤 7 中的图像 1,2 iView-776TPCII Motherboard Replacement, Camera Assembly: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      Heavy-Duty Spudger
      • The camera module is located in the upper-right corner of the tablet.
      • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
      • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
      • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
      询问修复机器人
      添加评论
    2. iView-776TPCII Motherboard Replacement: 步骤 8 中的图像 1,2 iView-776TPCII Motherboard Replacement: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
      • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
      • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
      询问修复机器人
      添加评论
    3. iView-776TPCII Motherboard Replacement: 步骤 9 中的图像 1,1
      • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
      询问修复机器人
      添加评论
    1. iView-776TPCII Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 iView-776TPCII Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 iView-776TPCII Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
      • Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
      • Check "Screwdriver Best Practices" as needed for help on how to properly use a screwdriver with your device.
      询问修复机器人
      添加评论
    2. iView-776TPCII Motherboard Replacement: 步骤 11 中的图像 1,2 iView-776TPCII Motherboard Replacement: 步骤 11 中的图像 2,2
      在这个步骤中使用的工具:
      • Use the 45 degree tweezers to lift the black section of the digitizer ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • When reassembling the device, be sure to fully secure the ribbon cable back into the ZIF adapter.
      询问修复机器人
      添加评论
    3. iView-776TPCII Motherboard Replacement: 步骤 12 中的图像 1,3 iView-776TPCII Motherboard Replacement: 步骤 12 中的图像 2,3 iView-776TPCII Motherboard Replacement: 步骤 12 中的图像 3,3
      • Use the 45 degree tweezers to lift the black section of the LCD ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
      • The motherboard is now separated from the digitizer and front panel and can be safely removed from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G2
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 940
